TO 35 oil flow to head?
Lou
03-29-2005 08:48:08
Ive got my 35 gas that I payed too much for in the shop. No oil getting to the top of the engine. Needs new valves ect. Mechanic is trying to figure out if there is a tube that brings oil to the top of the engine?No tube there now should there be? Thanks Lou
Dave in CA
03-30-2005 18:54:36
 Re: TO 35 oil flow to head? in reply to Lou, 03-29-2005 08:48:08
Oil is supplied to the rocker arms,on the Z134, through a hole in one of the rocker arm stands. That is supplied through a galley from the cam. Sometimes the galley gets plugged between the cam and rocker arm shaft.
Dale in Mn.
03-30-2005 19:55:14
 Re: TO 35 oil flow to head? in reply to Dave in CA, 03-30-2005 18:54:36
My father inlaw has a 59 TO-35 that wasn't getting oil to the head,found out who ever worked on it before he bought it put the rear main bearing in wrong,so oil was not being pumped up to head.Lucky it was caught early enough so it didn't ruin motor.Put all new mains in and it runs fine know. Just finished putting it all back together on Monday.
Lou
04-01-2005 08:05:15
 Re: TO 35 oil flow to head? in reply to Dale in Mn., 03-30-2005 19:55:14
Thanks for the info gentlemen. This motor was worked on by the guy I bought it from, Looks like he screwed it up. Thanks again Lou
