sheer tube replacement
steve hudson
03-29-2005 06:25:20
i have a massey ferguson 135 and the sheer tube has broken from the gear box to the differential i was wondering if anyone has replaced this part and what kind of a job it would be to replace
DavidP, South Wales
03-29-2005 12:04:13
 Re: sheer tube replacement in reply to steve hudson, 03-29-2005 06:25:20
Hi Steve,
Actual replacement of the tube is very simple....getting to it is another matter. I have only removed and replaced them with the hydraulic cover removed. Depending on the spec of your tractor, multi-power, IPTO etc it might be possible by removing both side covers work 'blind' by leaning over the hydraulic cover but I think it would be very difficult. It would be far easier to remove the hydraulic cover (See Big Dean's Pages) and do the job properly. You will find that it helps if you have three hands. While you are in there you can check the hydraulic filter as well. Make sure you have the correct size split pin 354 416 X1 and select a hole to give free fitting but with minimum end float. Fit the tube with the selected hole horizontal to reduce any chance of the pin falling out and perhaps disappearing under the pump.
Regards
David P
