tractor wont start
farmers . wife
03-27-2005 17:57:41
we have a massey fergeson 470 shovel loader with a 236 perkins diesel engine in it this is a 4cyl engine that is mounted backwards in the loader so where is the#1 cyl what is the firing order and where do i find the timing marks to make sure it is timed corectly any help thanks mike
MHF
03-27-2005 20:45:12
 Re: tractor wont start in reply to farmers . wife, 03-27-2005 17:57:41
I have a couple of questions. First did you pull the injection pump off? If you did there is a blind spline on the drive shaft and pump so you should not have been able to get it out of time. Did you overhaul the engine and not get the timing gears lined up right? I would take a guess that you probably just have air in the fuel system if you have all the air bleed out the fuel filters and injection pump and it is still not starting take a 5/8 wrench loosen the injection lines at the injection nozzles roll the engine over with starter until fuel starts to pump out of lines. Tighten the line back up and then try to start it. Are there any saftey shutdown guages with a fuel solenoid that might not be opening?
