MF 285 Stuck in 1st Gear
KBrauen
03-26-2005 12:37:58
I recently purchased a used 285 w/ 1340 hours. The first time I used it, it locked in first gear and couldn't get it out. Any ideas on what caused it? I don't want it to happen again.
toolbox
03-27-2005 23:38:18
 Re: MF 285 Stuck in 1st Gear in reply to KBrauen, 03-26-2005 12:37:58
is it a multi-power transmision?
Big Dean
03-26-2005 13:34:26
Unsticking Shift lever
The transmission main shaft lever hanging up is very common on most models of the MF tractors. The shift lever is held down by a spring & when you start to shift it you will unconsciously lift upon the lever. This causes the shift lever to go into the other shift fork on the other shift rail. That rail can not be moved because of the lock on the back of the transmission to prevent it from going into two gears at the same time. Once you have both shift rails in the neutral position you can then move the shift lever.If you will use the palm of your hand When changing gears to push the lever into neutral then get hold of the lever to put it in the gear you want it in. Shifting it that way it will not hang on you again. Below is the article from my web site that tells how to get the lever unhung. If I can be of further help Email me at [email protected].
Getting the main shift lever unstuck
Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse. Pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a
