MF 245 electrical problems
Scott Landret
03-26-2005 10:48:23
Alternator quit charging. Put a new alternator and new battery on - it boiled the acid out of brand new battery. Do you have any suggestions?
acmfmh
03-26-2005 16:08:45
 Re: MF 245 electrical problems in reply to Scott Landret, 03-26-2005 10:48:23
Check to see if the tractor has an external voltage regulator. Sounds like the regulator is stuck open. This allows to much voltage back to the battery causing your problem.
If the alternator has an internal regulator then you will probably want to return it.
Doug in OR
03-27-2005 16:40:10
 Re: MF 245 electrical problems in reply to acmfmh, 03-26-2005 16:08:45
Not so fast. Check a few things first. What voltage is at the battery when the engine is running? If it is between 13.5 and 14.5 volts, there is nothing wrong with your charging system. Your battery may have a shorted cell. This would cause the other cells to boil.
acmfmh
03-27-2005 17:30:57
 Re: MF 245 electrical problems in reply to Doug in OR, 03-27-2005 16:40:10
I do not disagree with your statements. But, if the alternator was initially bad and the system has an external regulator I would bet that the regulator is also bad. Stuck open. If you put on a new alternator and battery change the regulator also. The post stated that he installed a new battery already. Could a new battery have a dead cell? Yes. I still think the regulator is bad.
