Massey 265 diesel - Power Steering Question
shane(tx)
03-26-2005 08:04:05
How would you bleed the power steering system on a Massey 265?
I recently replaced both hoses on the power steering system. How do you bleed the air out of the line to make the power steering work properly.
The reservoir is full yet the steering is still unresponsive.
sam in mo
03-27-2005 05:28:19
 Re: Massey 265 diesel - Power Steering Question in reply to shane(tx), 03-26-2005 08:04:05
Look on the right front side of the engine.The P S fill spout or pump should be located there.If you put P S oil in the trans or rearend houseing I would think about draining the oil out and putting the correct oil back in. Ask big dean about this he is sharp on M F tractors and would know what oils to use and if they will work mixed up or not.
Big Dean
03-26-2005 13:40:58
Bleeding the air out of the power steering system. You always fill the reservoir with the engine running. After you have it full, turn the wheels from stop to stop several times to disperse the air from the system. You may have to fill the reservoir a couple of times if there is a lot of air in the system.This is done with the plug out
shane(tx)
03-26-2005 14:17:10
 Re: Massey 265 diesel - Power Steering Question in reply to Big Dean, 03-26-2005 13:40:58
Well then maybe bleeding the system isnt the problem here.
Both hoses on the steering system were recently replaced, and the reservoir was filled without the engine running. once the engine was cranked the reservoir drained, yet the dipstick is showing that the level is full.
I am not familiar with this machine (fathers equipment), and all work to this point was done before i arrived on the scene.
Is the power steering reservoir the hole just to the left of the shifter between your legs?
thanks.
Onefarmer
03-26-2005 20:33:54
 Re: Massey 265 diesel - Power Steering Question in reply to shane(tx), 03-26-2005 14:17:10
The filler on the left side of the shifter is the rearend/hyd oil filler. The power steering is a separate unit.
Onefarmer
03-26-2005 20:31:48
The power steering pump is on the right side of the engine. It gets its power off the timing gears. As stated before leave the filler plug out and keep filling it as you turn the steering wheel left and right. Should bleed out the air fairly fast.
