Compression poundage vs. ratio in mf-35
Craig in Denver
03-24-2005 12:06:09
I tested compression in my mf-35 & found all cyl's to measure 102-112 psi. Can I figure whether I have a regular (6.6:1) or a high altititude (8.?:1) engine based on these compression #'s
Thanks Craig
deerhound
03-25-2005 08:23:20
 Re: Compression poundage vs. ratio in mf-35 in reply to Craig in Denver, 03-24-2005 12:06:09
If you know your tractor"s serial # it will have an H in it if it is a high altitude engine.. MY tractor is SHM XXXXX X. A regular lower compression engine will have a G in the number, SGM XXXXX . There is a High Altitude decal at the botom of the dash. There is a plate on the engine just above the distributor that says do not operate below 5000 ft. on the high altitude engine. There is also a decal stating that the engine is high altitude only under the access door on the hood. Hope this helps.
Dale
Jerry/MT
03-24-2005 19:10:21
My educated guess is that you have a 6.6:1 copression ratio. The nominal "new pressures" would be around 125-130 psi and the min acceptable is a round 85-90 psi.If you had an 8:1 compression ratio, you'd be looking at something like 131-145 psi based on your 102-112 psi numbers (More like 165 psi if it were brand new.). These assume that you don't have a worn out high compression engine. I'm not sure how you can positively tell whether you have a a "high altitude" engine or not. Maybe someone more knowledgable about the subject than I can tell you.
