MF 65- Genny loses polarity
Our Farmer
03-24-2005 06:05:56
If the tractor sits for a few days without running, I have to re-polarize the generator. After that it charges fine. Until it sits again for a few days. Any idea as to why this is happening? All wires and connections look good.
Bob
03-24-2005 10:36:50
 Re: MF 65- Genny loses polarity in reply to Our Farmer, 03-24-2005 06:05:56
Clean the commutator, and the slots between the commutator bars, and make sure the brushes are loose and in good condition, and the brush connections are clean and tight. If this does not help, likely there is a partial short, or leakage in the armature.
At startup, the generator must begin to charge using the slight residual magnetism left in the pole-pieces, so everything has to work just right, so the slight voltage initially produced can further magnetize the fields and "ramp up" charging.
