Massey Harris Tractor age
Josh Brown
04-21-2000 06:55:20
I Just bought a Massey Harris Jr.? Tractor and would like to now the age of it and where I can get brake pads. The only numbers on the tractor are located by the shifter, they are 7407A.The former owner could not remember if it was a 1940 or 1941. Thanking you in advance
Rob
04-21-2000 11:06:54
 Re: Massey Harris Tractor age in reply to Josh Brown, 04-21-2000 06:55:20
There should be a plate on the right side of the tractor frame as you are looking at it from the front. On my MH 44 it is right in front of and below the cluth pedal. It should have the model and the serial number. Also look at the rear axle mine housing mine has a casting number and the date it was cast.
Bob of Virginia
04-21-2000 07:32:49
Josh, if you click on "Tractor Shed" on the left of your screen and then Massey Harris you will see a selection of serial numbers and under this page is your Jr. The Serial # is 6 digits and will give you an idea what to look for. The number listed under the year is the first one made in that year, so by looking at two consecutive years you can figure out the vintage of your tractor. Good Luck!
