MF165..can I add down pressure
Steve
06-10-1999 05:24:06
I am looking at a MF165, the unit is in good shape and has a factory loader.. i don't have the model #. I am curious if i can add down pressure to the loader for light digging. I am new at this but down pressure means it should lift the front end of the tractor of the ground and the current loader does not do that. The current loader is hydraulic. What would be involved, can it be done and how much should it cost? Thanks in advance
Dennis
06-10-1999 09:23:05
 Re: MF165..can I add down pressure in reply to Steve, 06-10-1999 05:24:06
you'd need to replace both main cylinders with double acting rams, the control levers will need to be replaced with a double acting lever as well. Also new hoses will need to added to the new rams.
I looked into doing this and using the Northern Hydraulics catalog foud it would cost me over a grand. Haven't done it yet but am still considering it.
