MF 135- Front loader
Kristi
03-14-2005 14:28:54
Does anyone know where to get a front loader for a massey ferguson 135? Are there any other compatible Loader attachments?
Thanks,
Kristi
Ida Red
03-18-2005 04:51:21
 Re: MF 135- Front loader in reply to Kristi, 03-14-2005 14:28:54
I have a good canvas heat houserwith side curtains, windows and hinges door for your 135.Red
Kristi
03-18-2005 04:55:38
 Re: MF 135- Front loader in reply to Ida Red, 03-18-2005 04:51:21
Do you have pictures of the canvas heat houserwith side curtains, windows and hinges door ?
Thanks,
Kristi
Rod in Smiths Falls, ON,
03-15-2005 16:48:46
I had a guy install an old loader on my MF35. He just grabbed his cutting torch and started making plates from 1/4" steel until he had a fit. Deciding the whole rig wasn't sturdy enough, he sent me to a metal yard for a piece of 2X6" beam to run across underneath the frame as a base.
He cut the frame and re-welded to make it easier to get on and off the machine, and moved supports around to fit the tractor.
From what I saw over two weeks of part-time fabrication, pretty well any loader can be installed on a tractor like the 35/135. The price skyrockets when new cylinders are needed, though. They ran 200 to 250 CDN for the three my rig got. With hardware and 23 hours of labour, the bill came to a bit over $2100 CDN.
A new unit might prove to be a better value.
ben uk
03-15-2005 10:57:04
The originals are easy to find....in the UK anyway. Check Ebay
William Bos
03-14-2005 17:44:10
Hi,
There are lots of companies that make loaders for the ever popular 35/135. It all depends on how much you want to spend.
www.buhler.com make loaders
www.alo.com makes them
woods also makes them
frey industries does too.
Have a look, or go and shop around at your local dealers. Dont forget some pics afterwards!!
Good luck
Take care
Will
