44-6
dirt digger
03-13-2005 18:29:44
Hello,I need a govener housing for a continental 6.I could use complete throttle linkage to.I would also like info where to get parts.thanks
Tom Dold
03-15-2005 13:49:26
 Re: 44-6 in reply to dirt digger, 03-13-2005 18:29:44
dirt digger
I beleive I have a governor housing that will fit your 44-6. It is off from a different continental 6 cylinder but if you only need the housing it should work. The 44-6 with a distributor has a smaller gear than most continental engines. It was designed that way so a hydraulic pump could be driven off the front side of the governor housing. I do have a complete new governor for a 44-6 Massey Part #763130M91 as well.
Tom Dold
Dold implement Co.
201 S. Main St.
Howard SD 57349
605-772-4541
[email protected]
