MF 35 deluxe
JoeyVet
03-09-2005 11:56:22
I"ve been hunting for a MF 35 and came
across a 35 deluxe with 5 foot bushhog for $3000.00. Is this a good deal? Any big pointers I should look/ask about? I"ve asked about the engine type/model but haven"t had my call returned. Thanks!
JoeyVet
03-10-2005 07:00:50
 Re: MF 35 deluxe in reply to JoeyVet, 03-09-2005 11:56:22
Okay guys, you"re advice has been great about this little 35! Thanks so much. Here"s my next question - the seller says it has a 4 cylinder sgw gas engine. What does the sgw mean? Also, he says it burns "some" oil. Any advice here? Thanks again for the help - I grew up on a farm in central Texas - but my older brother and dad did most of the machine work - I was more into the cows and horses we had. Thanks again.
phil(va)
03-10-2005 08:51:05
 Re: MF 35 deluxe in reply to JoeyVet, 03-10-2005 07:00:50
If it smokes out exhaust, chances are it needs valve job, valve seals, etc. If it smokes out breather pipe, especially when pulling hard, chances are it needs piston rings. Full overhaul (top and bottom of engine) by pro (you said you weren't a mechanic) is maybe $1400, not including clutch, which you might want to inspect while tractor is apart if you go that route.
jrsn
03-10-2005 08:34:54
First letter(chassis type):
S = Lo clearance (std)
R = Row crop twin front wheel
T = Row crop single front wheel
C = high clearance
U = Utility
Second letter(fuel type):
G = Gas
B = LP
H = High Altitude
N = Diesel
D = Direct Injection
Third Letter(Clutch type)
M = Dual - Reg. Transmission
F = Single
W = Multi-Power
Chuck (CA)
03-09-2005 20:21:05
Rod described this tractor perfectly. I bought one last summer. It has the 4 cylinder Standard diesel and is a good motor, but doesn"t like to start easily. A little shot of starting fluid while cranking and throttle open just a bit and she"ll fire right off. And then she"ll run all day. It sips fuel and goes a looong time between fill ups. I never could come up with a reason to use the ground speed on the PTO. It moves my 5 ft brush hog without a whimper and runs around 150 degrees. After she"s warmed up, she holds 50lbs oil pressure at throttle and 35 lbs at idle.
I also like the low range on the transmission and am currently looking for a good deal on a tiller; something you couldn"t use if you just had the high range. Needless to say, I highly recommend it.
BTW, I paid $3000 for it with no attachments, but the engine was rebuilt in 1998 and the front end was rebuilt in 2003.
Good luck and let us know.
Chuck
Rod in Smiths Falls, ON,
03-09-2005 17:07:11
Nice tractors. If it's a diesel, count the number of cylinders. Three is a plus, rather than four, as the Perkins diesels have a reputation for starting easily.
There will be a plate on the dash with the serial number and model designation. With that information you will be able to find its age and where it was built. This becomes quite important when shopping for maintenance items.
The engine should run smoothly and idle down to about 400 rpm without stalling. There are two PTO settings, one achieved by raising the PTO lever up, and the other by pushing it down. Don't be overly concerned if the PTO grates going into gear. Jiggle the throttle or shut off to switch in, until you are familiar with it. The lower setting is called "groundspeed PTO". Avoid using it until further notice. Use the upper, conventional PTO setting. The other one can cause the implement to turn backwards and damage it if you don't know yet what you're doing.
Check the coolant level and add anti-freeze if needed. Check the engine oil for condition and level. The transmission oil dipstick is by your right heel. There should be oil on the stick.
It's tricky getting the level right on the transmission because of the three chambers, and there is a lot of oil in there, so go carefully.
So these are the answers. What was the question? I have yet to encounter anyone who has owned one of these tractors and not liked it.
Good luck.
phil(va)
03-09-2005 15:18:36
Assuming it is in decent shape, this is an excellent deal. The deluxe has a two stage clutch. Test it by depressing half way to a "notch" you can feel with your foot and the tractor, in gear, should stop; then depress the rest of the way and the PTO, turned on, should stop. (If you have it on, the PTO should turn when you have the clutch depressed half way.) Of course, check all the other normal things you would look for. I'd run it until it is warm and make sure no oil and water are mixing and no leaks in block. Raise an implement and see if it holds. Check brakes, tires, charging system, etc., etc. Look at rear rims to see if rusted out. Also, note the steering. Steering boxes are sometimes hard to find, and sellers are "proud" of them if they have one available.
bc
03-09-2005 18:51:40
 Re: MF 35 deluxe in reply to phil(va), 03-09-2005 15:18:36
i paid 3,000.00 for mine two years ago. it came with a 7' blade, 5' finish mower, and a plow. never had a bit of trouble with it and its a perkins gas...
well i take that back.. the multi-power started leaking this year..
bc
03-09-2005 18:54:08
 Re: MF 35 deluxe in reply to bc, 03-09-2005 18:51:40
oops. meant continental gas not perkins.. sorry
txblu
03-10-2005 06:04:15
 Re: MF 35 deluxe in reply to bc, 03-09-2005 18:54:08
Fixin to say, thought Perkie was a diesel house.
(Got one in my 35)
Mark
Gerald J.
03-10-2005 08:23:47
 Re: MF 35 deluxe in reply to txblu, 03-10-2005 06:04:15
Don't know about the 35 but MF used both Continental and Perkins gas engines in the 135. The Perkins gas was 3 cylinders like the diesel.
Gerald J.
txblu
03-11-2005 06:08:32
 Re: MF 35 deluxe in reply to Gerald J., 03-10-2005 08:23:47
Okay. Guess I have only been exposed to their diesels in tractors, industrial equip and marine applications.
Mark
