MF 360 Brake
J. Kelly
03-07-2005 07:25:14
I have a nice MF 360 with 1750 hours. The right side brake has no pedal resistence at all...nothing. The left brake works fine. Any ideas on the problem.
Thanks
Jk
Toolbox
03-07-2005 22:54:12
 Re: MF 360 Brake in reply to J. Kelly, 03-07-2005 07:25:14
The 360s here in the UK have hydraulic brakes without rods, if yours has this, it may be, you have a fluid leak from one of your cylinders.
Big Dean
03-07-2005 14:30:53
Follow the rods from the pedals back to the rear axle housing to the lever that they connect to. There will be a bolt with a nut on it coming from the axle housing through that lever that nut is used to adjust the brakes. Either the brakes need to be adjusted or the bolt is broke. or could be a pin has came out inside. If I can help further Email me.
