mf35 wont turn over
foyamot
03-06-2005 10:26:59
mf35..z134 eng. had it about 6 mo. always started up right away and ran well, although it would "poof" some, and black soot on inside of tailpipe and around sorrounding area. yeaterday cranked it up, started, then died. since then will only spin, but not start. changed plugs about 5 mo. ago, yesterday changed ign. coil and new coil wire. have spark although it appears weak(dont know how strong it is supposed to be on tractors)cleaned air filter bath about 5 mo, ago also, and since then have put app. 20 hrs on tractor.any sugg would be appreciated.
Gerald J.
03-06-2005 16:00:00
 Re: mf35 wont turn over in reply to foyamot, 03-06-2005 10:26:59
Yellow spark? Replace the condenser.
Gas in the tank? That happened to me last year. Gas valve turned on at the gas tank?
I also had an intermittent ignition switch.
Stuck float needle valve? Is it getting fuel to the carburetor? Filters, lines, and screens plug up with varnish just sitting.
Gerald J.
FOYAMOT
03-19-2005 11:41:50
 Re: mf35 wont turn over in reply to Gerald J., 03-06-2005 16:00:00
tHANKS FOR THE INPUT..BIG DEAN E-M THE OTHER DAY TO TAKE OFF THE AIR HOSE TO THE CARB AND CHECK IN THERE. TURNS OUT THE BUTTERFLY WAS STUCK..SPRAYED IN SOME CARB CLEAN..AND GUESS WHAT!..STARTED RIGHT UP..THANKS AGAIN FOR A GREAT WEB SITE!
