HELP! How can I tell the difference between
Glen Thibodeaux
03-05-2005 19:04:29
How can I tell the difference between the smaller Massey"s. And where is the ser. number plate located? The one I found is small, it might be a Pony, but I"m not sure. It has a 4 cyl. gas engine, hydraulics system, PTO, 3 speed trans., and the batt. is located in front of steering wheel. What should I check on the tractor to determind the model? Thanks for the help.
Glen
james shaw
03-06-2005 10:44:00
 Re: HELP! How can I tell the difference between in reply to Glen Thibodeaux, 03-05-2005 19:04:29
check serial number on engine a pony has a 62ci continental engine a pacer has a 92ci engine
Bruce Colbourne
03-06-2005 01:54:48
Both the pony and pacer have three speed transmissions.The serial number is located on the right side of front frame,above the front axle.Engine serial number is located on left side of cylinder block
