3 MH 81 restoration ?'s
Kurt Smit
03-03-2005 15:38:30
I"m restoring a MH 81 and can"t find where the temp gauge bulb screws into the engine block/head. The manual I have shows it to have a temp gauge. Did they omit them on some tractors? Or, has someone deleted it? I"m also in need of a 2 postition push/pull hi/lo charge and light switch. Anyone know where I can ge one that is 6 volt. Finnally, it looks from the manual they ran a straight pipe instead of a muffler. Is this correct. Any and all info is greatly appreciated.
Thanks, Kurt
Kurt Smit
03-05-2005 05:37:42
 Thanks! in reply to Kurt Smit, 03-03-2005 15:38:30
Thanks for the info. Hopefully, I can wrap this project up.
Kurt
Alberta Mike
03-04-2005 03:59:41
 Re: 3 MH 81 restoration ?'s in reply to Kurt Smit, 03-03-2005 15:38:30
The flathead Continentals had the temperature sensing bulb threading into the left side edge of the cylinder head, some near the rear and others near the center depending on the tractor or what was ordered when they were made up I guess. I'm not sure if I've ever seen one without that threaded hole in there, all the one's I've seen have them, usually near the back.
