1105 MF Tractor gears
John Walker
03-02-2005 18:06:01
Will only go into 2nd gear????
chuckinnc
03-03-2005 13:35:53
 Re: 1105 MF Tractor gears in reply to John Walker, 03-02-2005 18:06:01
You can take the plate off that covers the gear
shift lever, see if it will shift then. Those slots in the plate will not let you shift all the
way if the tractor has alot of hours on it. I had to enlarge the 2nd & 3rd gear slot with a
rat tail file on mine.
STUDIEdiesel63
03-02-2005 18:42:43
Will the shifter slide back and forth all the way through it`s neutral range? If not take the shifter gate panel off the dash and check linkage,pin may have come out of adjusting clevice,or may simply need to adjust linkage,also have seen shifter rods break right at the bottom of the threads in there too. good luck.
