TO35 Diesel Standard fuel troubleshooting
Pojawis
02-28-2005 15:53:45
My TO35 has the 4 cylinder Standard engine. It started and ran as usual for the few hours I was skidding logs and then plowing (pulling) snow. The rpms lagged slightly, then increased, then cut off. I replaced both fuel filters, cleaned the bowl, primed all locations, and restarted. It started (with ether) and ran for about 15 minutes when the same symptoms re-occured.
It seems to be a fuel problem, but am about at the end of my troubleshooting abilities. ANY help, ideas, would be welcome.
the preacher
02-28-2005 16:58:59
 Re: TO35 Diesel Standard fuel troubleshooting in reply to Pojawis, 02-28-2005 15:53:45
also, while you are in the tank, drain a little fuel, and check for water. i have gone on a few service calls this winter for ice forming around the fuel pick-up inside the tank.this will cause problems similar to what you described.
Pojawis
03-01-2005 03:00:46
 Re: TO35 Diesel Standard fuel troubleshooting in reply to the preacher, 02-28-2005 16:58:59
Thanks Chip and preacher for the quick replies.
I"ll check that out today, soon as the sun gets up. -- I did have some water (thumb sized blob) in the fuel bowl and a couple oz in the water separator (1st filter). I suspected water in the lines and ran the salamander to melt it all.
I"ll post the results.
Chip Fontaine
02-28-2005 16:46:26
Remove the screen filter in the tank by taking the sediment bowl out of the bottom of the tank. These screens will plug up with sediment and fauled fuel. A good cleaning of this screen should help. I had this happen twice on my MF35 diesel.
