MF255 Won't Crank
Jerry (Al)
02-26-2005 10:37:29
Electrical issue. Put on a new battery and nothing. Any comments on how I approach it? How can yo0u try to jump it at the starter? Fuses? Cables? Need some suggestions of logical approach to take in checking it out.
Ed in Tx.
03-02-2005 09:52:44
 Re: MF255 Won't Crank in reply to Jerry (Al), 02-26-2005 10:37:29
What is it doing when you turn the key clockwise to start? Nothing or engine turns over but does not fire?
Make certain you have the gas shut off lever pushed all the way in, located below the light switch. If engine does not turn over check the 2 fuses to the left of the light switch. Push them in and turn counter clock wise. If one is blown,replace with a 10 amp automotive type. If it continues to blow look for wiring with insulation removed. I had one of these 255, found the wire causing the trouble under the diesel tank. Rubber supports for the tank worn out causing tank to sit againt the frame, wire was run under the gas tank. An easy fix, once I found it!
Good Luck
Big Dean
02-26-2005 13:28:26
Jerry email me with your Email address I have some pictures that will help you trace the starting system till you find the problem. .
