Oil Specs.
Frank W
02-25-2005 19:08:59
For a MF 135 1973, Motor oil & Hdy oil. How Qts for each and what type motor oil is best to use in in the engine that has a lot of hrs on it. Unknown what type was used before.
Later
{:-{) Frank W
TomTX
02-26-2005 03:12:25
 Re: Oil Specs. in reply to Frank W, 02-25-2005 19:08:59
Motor: Mobil Delvac 1300 15W40, or Shell Rotella 15W40
Hydrolic: MF PermaTran III
Quantities: Operators Manaul from MF Dealer
Jerry/MT
02-25-2005 21:14:26
Can't help you with the quantities but do a search in this forum 'cuz the info is most likely in the archives. The engine was probably speced for SAE 30 WT so you can use 30, 10W30 multi-viscosity and if you have a lot of wear, 10W40, 40, or 15W40. You can use the latest API classification oils as they are backward compatible. Hope this helps.
