MH-44 Plug Wires?
Ian Tomlinson
02-25-2005 11:19:37
I am gearing up to restore a Massey Harriss 44. I need to get it running a little better in order to move it. I ordered up new ignition parts and a new carb. Somehow my order arrived without new plug wires. My question - can I use generic (automotive) plug wires or are do the wires in these old machines need to be different?
msb
02-26-2005 18:09:53
 Re: MH-44 Plug Wires? in reply to Ian Tomlinson, 02-25-2005 11:19:37
www.brillman.com can furnish the old original type spark plug wiring including any wiring harnesses you may need.
Dr. Chris
02-26-2005 16:38:32
Maybe thats why I'm always running rich no matter how I adjust the carb. Not enough spark will do that!! It all makes sense now.
RandyR
02-26-2005 15:56:05
Hi,Ian. The coils on the old tractors just don"t put out enough voltage to give a good spark with modern redio supression resistor wire. Use good old copper wires. TSC sells universal sets for that. Check out the posts by Dell(WA) on the Ford N section. He spent 40 years as an electronic engineer, so he"s a good source of info.
Alberta Mike
02-26-2005 05:36:15
Hat to contradict the Doc down below but see if you can find some of the older steel-braided wires. You'll probably have to get a set made up or solder the ends on yourself. The bulk wire is available at a good auto supply house as well as the wire ends. The newer wires take more voltage to conduct enough current to make a real hot spark at the plug and the old electrical systems don't kick out enough. At least that's what I've been told and experienced.
Dr. Chris
02-25-2005 14:06:42
A generic set will work great.
