1954 ferguson engine problem
earl morris
02-24-2005 13:56:46
the engine has spark at no three cylinder but plug on inspection is wet with fuel also small backfires through air cleaner engine starts easily but runs with a miss have replaced points haven't set timing don't know why the engine doesn't seem to fire on no 3 even though spark isn't as strong as on no 4 cylinder leeds ok and replaced plug.
Hz
02-25-2005 15:06:32
 Re: 1954 ferguson engine problem in reply to earl morris, 02-24-2005 13:56:46
You sure you didnt interchange leads to plug 3&2 - will give rough ride and backfire
marlowe
02-24-2005 18:26:04
burnt intake valve. do a compresion test
