Injection timing (4cyl FE35 diesel)
Peter Booth(AUS
02-24-2005 01:15:30
Hi all,
I now have a service manual (thanks Paul) . However about the only thing it doesn't tell me is how to test and set the injection pump timing. Is this possible or is it non adjustable.
Peter
Toolbox
03-05-2005 09:30:23
 Re: Injection timing (4cyl FE35 diesel) in reply to Peter Booth(AUS), 02-24-2005 01:15:30
Its the letter G that you need to line up through the side of the pump, and make sure the drive is turned the correct way to take any slack out of the timing chain and drive gear
Thomas
02-24-2005 12:16:45
There's a 1/4" hole on the back of the flywheel housing on the pump side looking from the front of the tractor, going into the flywheel. You can lock the flywheel on the no 1 TDC stroke with a 1/4" drill, and then remove the cover plate from the side of the pump. I can't remember the letter off the top of my head, but I've a feeling it's 'C', can anyone else help here? Loosen the three bolts and rotate the pump until the letter lines up with the mark on the circlip inside the pump. If the pump drive gear train has been removed you will need to set the pump and engine to their marks before fitting it back on. Don't make the mistake I made on the first one of these I ever did, timing it 180� out. It ran, just, but got very hot and cracked the head!
