questions on mf 85 lp, just got her home
i r baboon
02-21-2005 18:45:55
thrilled 2 have her. is it neg ground? any things to check for? owner said pin fell out of whatever drives hyd. oil pump?? pump is out & normal. what may have failed? can i make the belting joint at front end of steering shaft? how? what fluids @ final drives, etc? be blessed, nik
85 and 88
02-22-2005 18:28:59
 Re: questions on mf 85 lp, just got her home in reply to i r baboon, 02-21-2005 18:45:55
Neg ground 12 volt, coupling for hyd pump could have been put on backwards, and, it does have a pin it it, if backwards, coupling will slip off shaft, backlash coupling is readily available from MF, easier to buy than make, change the press-in pin in the steering gear box to a 1/8 in grade 8, easier to go in and out, permatran in rear end instead of 90 wt mineral oil (90 wt caused early rear end failures)but orig shop book still calls for 90 wt,never revised that I am aware of, what else? some people don't like 85 because power steering pump activates pto, so if power steering pump fails, pto won't work, as far as engine, trans, rear end, a heckacious set up. Can find most gaskets. If you take care of it, I doubt that you'll ever wear it out.
