what model and year
eric60i
02-21-2005 15:45:53
i found a massey-harris in a junk yard.the only numbers i could find on the trans.case where 762485 mi with a (s) below that. it has 4 cylinders,hydrolics of the front of the motor, 5 speed transmission,38 in tires. any idea what it might be. they are asking $600 for it don"t know if it will run or not. thanks eric
Bruce C
02-21-2005 16:21:27
 Re: what model and year in reply to eric60i, 02-21-2005 15:45:53
It sounds like you have model 30 or model 44.I am thinking more to the model 44 since it has hydraulics.Could you find out what size the engine is.If it is all there and the tin is not all bent up and motor is free it is wourth 5-600 hundred dollars.The tires also have to be decent condition.
eric60i
02-21-2005 17:14:54
 Re: what model and year in reply to Bruce C, 02-21-2005 16:21:27
if i read correctly in my book, having a 5 speed and a rear hydrolic lift would make it a 44 special. would this be correct? thanks, eric
Bruce Colbourne
02-21-2005 19:39:37
 Re: what model and year in reply to eric60i, 02-21-2005 17:14:54
From the data book I have on Massey tractors the hydraulic lift was a option on the 44 model.Hydraulics and mechanical power lift were options on the 44-6 model.Hydraulics and 3-point hitch were options on the 44-special.All three models of the 44 have 5-speed transmissions.
