MF 35 Stuck in 1st Gear
PRW-IN
02-19-2005 15:24:43
My MF 35 stuck in 1st gear. The high/low works all right. Can anyone suggest how to correct? The hole that the lever goes through doesn"t leave a very big opening to look/work through (especially if one doesn"t know what to look for). Taking the gas tank/steering column etc. off so the top cover of the transmission can be removed hopefully is not the only option?!?
Thanks to everyone in advance!
C. T. in Oklahoma
02-19-2005 15:28:30
 Re: MF 35 Stuck in 1st Gear in reply to PRW-IN, 02-19-2005 15:24:43
Go to Big Dean's site ->Link
There>Link is an explanation on how to correct it. Using his instructions, I have corrected mine in less than two minutes. I could explain it, but might lose something in translation, better for you to read it yourself. C. T.
PRW-IN
02-20-2005 15:18:18
 Re: MF 35 Stuck in 1st Gear in reply to C. T. in Oklahoma, 02-19-2005 15:28:30
Thanks C.T.! The fix sounds almost too good to be true, but it also sounds reasonable. You can bet I'm going to give it a try! Deans is a good website!! Thanks much for your help!
PRW-IN
Workbull Guy
03-01-2005 11:24:19
 Re: MF 35 Stuck in 1st Gear in reply to PRW-IN, 02-20-2005 15:18:18
I checked the information on Big Dean's website and it sounds exactly the same as what I did on my 1960 MF Workbull 202 a number of years ago, mine got stuck in reverse. I have done this fix twice now, it usually happens to me when I am on a slope and shift gears while putting some strain on the shifter due to the slant of the tractor. I now watch how I brace myself while shifting on a slope. When it happened the first time I had visions of having to split the tractor. After looking into the filler hole and probing with a 1/2 drive socket extension I was back on the road in no time.
