MF 35
Larry from NY
02-19-2005 13:02:15
My tractor's been sitting outside all winter. Today I tried to start it but it seemed as though the battery was dead. I tried jumping it but no luck. Finally, I remember that my dad always suggested that you start a vehicle with the clutch depressed. (I had been standing aside the tractor. When I did this it roared instantly to life. I let it warm, but when I backed off the clutch it stalled. The stall wasn't like a too rich/lean stall. It felt that the there might be a seizure. Earlier, when I tried to start the tractor without depressing the clutch, only the solenoid clicked, the emgine wouldn't even turn. For a while, I thought the engine seized.
I guess my question is this. Considering the bitter cold weather around here in the last few days (about zero F.), could any moisture in the transmission freeze up so bad that it refused to rotate when the clutch was released?
I have a z-134, gas, two stage clutch. The engine quits when the clutch is passing through the second (pto) stage.
Thanks for you collective help.
partsman
02-19-2005 15:53:37
 Re: MF 35 in reply to Larry from NY, 02-19-2005 13:02:15
Had the same trouble this winter with an IH 384. The PTO gears are very close to the bottom of the case (tranny gears too for that matter), and any ice build up will lock 'er up solid.
