engine rebuild MF 35
vernon spiller
02-17-2005 10:29:38
can anyone tell me the head bolt tightnes an tappet ajustment an how to do, for a massey ferguson 35 3 cyclinder engine number CL1817488C.
jack in NB
02-21-2005 04:39:53
 Re: engine rebuild MF 35 in reply to vernon spiller, 02-17-2005 10:29:38
Hello Vernon -
Cyl head bolt tourque is 50 to 60 ft-lbs. Sequence - start at the centre and spiral outward. I do it in several steps - snugging all up, then repeating all in 10 - 15 lb steps until I reach 60 lbs - about 4 trips around. You need a deep socket for the nuts on the 6 injector retaining studs.
I recheck all studs again after a warm-up. Means removing injectors and stuff, but seems to help.
Valve clearance .010 hot. You can set valves number 1,2,3 and 5 (numbering from the front) with #1 cyl on top dead center, then rotate the crank 1 complete turn and set 4 and 6.
I strongly recommend getting the MF or I&T shop manual - it's a small investment to help get the job done correctly, and can save many times the cost if it avoids a screw-up. You're spending a lot on parts and time now, and it's great insurance!
