I think I found the right (serial) numbers
Peggy in CT
02-15-2005 16:18:58
third party image
A while back I posted a message asking help to identify this tractor that we bought. The numbers we posted before were casting numbers. The ones we found now (with a little help from zip strip and you guys telling us where to look) are... the first one I think is a little under the screw head, but it could be a J or 0 then 10N-6. Then under those is printed CANADA then under Canada I think is M F. There is a faded bull painted on the side of the hood. The guy we bought it from, said that where he got it from said it is a 303 or 404 work bull, but he doesn't remember which one the guy said. I have mor pics if needed
Thanks alot.
ACEd
02-16-2005 11:55:52
 Re: I think I found the right (serial) numbers in reply to Peggy in CT, 02-15-2005 16:18:58
Nose does not look right for Work Bull, but I may be mistaken - look on frame rail / base of operator platform on drivers left - should be a serial number stamped into steel just ahead of shifter / left foot. My bet is its an I244 - made for military circa 1955. If so it will have a Continental 244 motor when you find motor tag it will be riveted to block - may also be steel stamped, but I don't know where - look on flat spaces - also tractor should have riveted tag - probably left side of frame, but lots of thoise are gone. Best. ed
Bruce Colbourne
02-15-2005 18:02:12
It is a work bull for sure.On the engine there is a number stamped into a machined flat surface.It will tell you what size the engine is.If you can send that number and the other pictures to my e-mail I will figure out which one it is for you.The numbers you posted don't match any numbers in my book on massey tractors.
