Help/Info/Pricing MF50 and/or MF283
Kirk Grau
02-15-2005 09:37:41
OK,
The 165 I had located was sold before I got back to it. Now I am looking for info/pricing on either of the following.
MF 50 w/ loader, diesel, nice straight tin, fresh home done paint, hour meter indicates 3000 and is working, everything is working, brand new tires. Smokes some on start-up then smooths out real nice. Loader seems a little slow and runs off of tractor hydraulics. $4500
MF 283 w/ loader, diesel, good tin, but weathered, hour meter not working, tires serviceable probably 50% tread. Runs real nice. Loader runs off of seperate pump and moves real nice. $8900 asking, but has indicated he can move on this.
Thanks Guys,
Not sure what I would do without all of you willing to share your knowledge and experience.
Kirk
TomTX
02-16-2005 05:21:02
 Re: Help/Info/Pricing MF50 and/or MF283 in reply to Kirk Grau, 02-15-2005 09:37:41
Would not get FEL without downpressure. Also would not pay any attention to the hours shown - most folks around turn them back. The MF 50 sounds like not so good a deal if you really want a tractor with FEL to do real work. Hold out for better. By the time you add pump, route, re-work or replace FEL, then you are way into too much $$$.
Lou
02-15-2005 12:05:50
Ive owned a MF 50 diesel with a loader for about 10 yrs, i love it. It has the front hydrolic pump and loader has down pressure, which to me is a big item. If tractors in good condition could be a big if, well worth 4500. Good luck.
Kirk Grau
02-15-2005 14:54:14
 Re: Help/Info/Pricing MF50 and/or MF283 in reply to Lou, 02-15-2005 12:05:50
This loader is piped to the tractor hydraulics and is a little slow. New filters/fluids might help a little. It also has one way cylinders (no down pressure). I really wanted the down pressure to help scrape out run-in sheds.
Thanks,
Kirk
Lou
02-15-2005 17:34:29
 Re: Help/Info/Pricing MF50 and/or MF283 in reply to Kirk Grau, 02-15-2005 14:54:14
The down pressure is a big help when you get stuck also. Lou
