Play in steering system.. how to remove?
Jim From Austra
04-18-2000 03:17:23
I have an MF-185 with power-steering (has same steering system as MF 168 175 178 etc..). I find that there is a lot of 'slack' in the steering system, about 6" movement back and forth at the steering wheel before i see any movement at the front wheels. Any ideas out there on where I should look for wear or adjustment? I did try to follow the instructions in the 'operators manual' for adjusting the power steering but it hasnt made any difference?
All replies appreciated!
Jim!
Bill
04-19-2000 16:23:04
 Re: Play in steering system.. how to remove? in reply to Jim From Australia, 04-18-2000 03:17:23
I have a MF-165 (U.S. model) that's had the same problem. Solution is to check the linkage between the bell crank on the steering pedestal (forward of radiator) and the power steering cylinder control valve. Any play here can cause the problem.
