MF 35 PTO saw
Dave Embertson
02-12-2005 15:26:34
I would like to use my MF 35 to cut firewood. My chainsaw is great, but it would be great if I could give my chainsaw a break and use the live PTO on my MF 35 to hook up to a saw rig/blade. Can I build one. What kind of setup is available.
Dave - Northern Michigan
res
02-13-2005 18:18:42
 Re: MF 35 PTO saw in reply to Dave Embertson, 02-12-2005 15:26:34
you can buy saw rigs that mount on your three point hitch and connect to your pto with a drive shaft.old ones used a flat belt drive from a adapter that you installed on your pto shaft,some were stand alone and a few were three point mounted .dangerous to buid your own ie saw balance ,bearing alingment,blade speed. i have used them DO NOT want to be day dreaming those i have used scream,get helper to work with you to take away chunks before they hit ground. just my 2 cents
Dave Embertson
02-22-2005 10:35:13
 Re: MF 35 PTO saw in reply to res, 02-13-2005 18:18:42
Where does one purchase such a rig?
