Very jumpy hydraulics on MF 50
KCTractors
02-12-2005 12:19:35
Hydraulics are very jumpy, so I took out the pump and the bottom of the front piston block was broken off, part#23 in the parts book( block, front pump cam). I would say that would cause the jumping right.Can I just replace that part or should do more? Then I noticed the differential gear are all chewed to shi$$, so I"ll have to replace that to, so I need some parts, anybody got some?
KCTractors
02-13-2005 10:24:46
 Re: Very jumpy hydraulics on MF 50 in reply to KCTractors, 02-12-2005 12:19:35
I have a question on the pinion shaft, how do I know if I have the short shaft or the long shaft, they both have the same amount of teeth and splines?
