Replacing pinion shaft-to-transmission coupler?
Darren in TN
02-10-2005 12:45:56
Howdy, all.
I promised to help a friend from church fix his tractor so we can use it for a service project. He broke something in the rear end trying too hard to pull a truck out of the mud. The dealer told him it was probably his diffy-to-tranny coupler, so we"ll go up there and pull the cover off tonight or tomorrow to check. If it is the pinion shaft or the coupler that broke, can they be replaced without splitting the diffy from the tranny? I"ve heard the coupler can be changed out through the PTO shifter cover, but I can"t seem to wrap my brain around that concept. Any advice out there? This is on a MF 231. I"m not an MF guy, so I don"t know how old that machine is.
Thanks,
Darren
Thomas
02-11-2005 08:27:27
 Re: Replacing pinion shaft-to-transmission coupler in reply to Darren in TN, 02-10-2005 12:45:56
Remove the lift cover, take the split pin out of the centre of the shear tube. Slide it back towards the diff. Pull the shaft out of the back of the transmission epicyclic (high-low). Then you can remove the shear tube. If it is already broken then it will be a lot easier. I don't think you would do it through the PTO shift cover as I don't think that you would have room to pull the shaft out. You could look through there to see what has broken. It would be worth checking through the gearbox filler cap to see whether there is any gearbox movement, to rule out a damaged clutch - the centre can rip out. Be sure to fit new O-Rings on the stack pipe when you replace the lift cover.
