French made MF
Maurice
02-10-2005 08:00:18
Hello all,
Does anyone on here know anything about a the French version of a Massey Ferguson. We have one that we think is a 39 MF built in 1965. Curious about parts for it. If parts are available. The 3 pt lift will not go up and down and the PTO does'nt turn. Anyone know what might be wrong with it?
Thanks for any info
Maurice
Ali, fae Crieff.
02-13-2005 02:34:13
 Re: French made MF in reply to Maurice, 02-10-2005 08:00:18
Maurice, If your tractor was built in 1965 it would have to be a "100" series tractor and they came as follows:- 130,French with 4 cyl Perkins, 132,German with 2 cyl Eicher,133,French with 3 cyl Perkins,139,German with 2 cyl Eicher, and of course the 135 built in the U.K.,the U.S.A.,Spain and France with a variety of engines. The French 130 has a fiter in the transmission under the pto shaft which might be wher your problems are coming from.Also the "8" in 825 denotes a French built model 25 as a "7" would indicate a U.K. built model,not 8 speed as Phil thought. Cheers, Ali.
bill lb
03-09-2006 18:46:03
 Re: French made MF in reply to Ali, fae Crieff., 02-13-2005 02:34:13
Ali,
Can you tell me where I can get info. in english on a French MF 133 diesel tractor?
Thank You,
Bill
phil25
02-13-2005 17:27:57
Let me the first to say i will learn something each day if i am willing to listen, thanks for the number correction, that was how i learned it.Mine being the only local 25 naturally seemed correct, never intend to lead/offer wrong advice, but is there an update on what was the problem? I know we all are curious, but too proud to ask.
Tell us good news oor maybe we have futher help to offer.
Regards to all involved
phil
phil25
02-10-2005 17:45:41
I have not located a model 39 but imaybe you mean model 25, another name is 825[8 speeds/25hp], non working lift could be a stuck spool valve in the control valve body[ common if tractor has been sitting a while], PTo could be a clutch gone or the final drive gear has stripped it's teeth or shaft spline connection is damaged?. Put the PTO into ground speed position[fully forward] and watch if it turns when driving the tractor. This will check that portion of assembly. IF nothing happens anywhere, possibly even the PTO shifting fork has become dislocated internally.
Only quick suggestions that sound bad at present, but hopefully its a small situation.:)
maurice
02-11-2005 10:48:44
 Re: French made MF in reply to phil25, 02-10-2005 17:45:41
I want to thank everyone for their help...now I know what to look for...Thanks again
Dr. F
02-10-2005 14:00:20
Sure it is a model 39? For a history on MF in France follow the link: http://www.terre-net.fr/dossiers/reportages_machinisme/Massey.ASP
ben uk
02-10-2005 13:07:32
PTO clutch?
Dr. F
02-12-2005 14:36:19
 Re: French made MF in reply to ben uk, 02-10-2005 13:07:32
PTO clutch? Yes, some versions of the 825 have a dual clutch.
