M-H SPECIAL DISC BRAKES
D. Redfoot
02-08-2005 15:14:56
I need new brake discs for my M-H 44 special . Haven't been able to locate any in my area (western Pa.). Does anyone handle or rebuild these ? Any help would be appreciated .
mhtriples
02-11-2005 16:25:32
 Re: M-H SPECIAL DISC BRAKES in reply to D. Redfoot, 02-08-2005 15:14:56
If you have an Agco dealer nearby ask for part # 1010340M93 I resently bought 4 new ones. A bit pricey at around $54 each as I remember. Good luck!
D.Redfoot
02-13-2005 13:48:34
 Re: M-H SPECIAL DISC BRAKES in reply to mhtriples, 02-11-2005 16:25:32
Thank you mhtriples for the part # . I'll be calling tomorrow to order them .
D Redfoot
Harris Guy
02-08-2005 15:52:01
About any truck brake shop should have disc brakes
to match up. While you have them apart, check out those hooked short tapered springs. Worthwhile to replace, since aged tension means less effective
brakes. They are available from MF, on latter SP
combines, or since Bendix design, IH disc brake
parts, 400 tractor,probably same on 350/450 part#.
D. Redfoot
02-08-2005 16:01:45
 Re: M-H SPECIAL DISC BRAKES in reply to Harris Guy, 02-08-2005 15:52:01
Thank you Harris Guy , This is finally my last fix before it goes to get painted .
D. Redfoot
