Massey 35 Perkings Cam Trouble
MF35Jim
02-07-2005 17:22:22
In the process of a total restoration of an old MF 35 1962 with a Perkins Diesel motor. Upon removal of the cam, it was noted that the middle journal (not lobe) has several groves in it. Also, so does the block. Q. Is this normal, or am I about to spend some $$$ to fix the problem. Also, FWIW, # 3 cyl had piston slap.
Here is a link to the project. More pictures to follow
Link
sibby(Aus)
02-07-2005 20:25:01
 Re: Massey 35 Perkings Cam Trouble in reply to MF35Jim, 02-07-2005 17:22:22
Jim, Are you sure someone hasnt screwed the wrong headbolt into that hole, does it line up with the hole and damaged it? cheers for now.
