Harris Guy or?
msb
02-07-2005 15:17:39
Found a 44 Special.Hood & grille could use replacing but repairable.Rockshaft is the only part of the 3 pt.there.Fenders are rough but I have some good ones.Steering wheel needs repaired.Engine supposedly runs good.PS from a 444 is included in deal.Tires are very good.Generator is missing.M & W clutch seems(feels) o.k..2200.How much in your opinion and are there that many Specials to be found out there? TIA,bob
Harris Guy
02-07-2005 16:16:05
 Re: Harris Guy or? in reply to msb, 02-07-2005 15:17:39
Bob,
Depends on your plans. These tractors are too old
for repairs from hard MH work. The S/N has to be about 55313& up for the heavier carrier bearings,
pinion upgrade. The M& W clutch would have to test
out 'well', since about zero parts. Rim rust, tire
size , cond, gear oil in the tranny case? Not too
excited on the 444PS, unless it was rebuilt. Your
engine, drive train #1 concern. Having the lift shaft is the key, to Hitch-All. You can retro the two point, after market 4600 Ford/MF175 parts,
Crafton Tractor, Van Buren,MO.Tires/engine/rims
can flex the price from 900, to $2K. No disc
brakes is a drop of 2-3 hundred. How much clutter(non-MH) on the Special? Gated shift, correct?
msb
02-07-2005 20:16:09
 Re: Harris Guy or? in reply to Harris Guy, 02-07-2005 16:16:05
Plan would be to restore it to go with the 44 & 44-6.Am a bit of a perfectionist so----Are parts available for the 444ps?I can rebuild about anything as a rule unless it takes special tools that I wouldn't have. Has some dual hooks on the wheels,but the drawbar isn't worn as bad as either the 44 or thr 44-6.It belongs to a friend so I think it probably does run o.k.since he said it did.No clutter except for the hyd oil filler cap.Some kind of pipe fitting on it now.Has what I think is a Schwartz front end.You lost me on the gated shift.44S was a 10 speed wasn't it?How can you tell if it has disc brakes? They visible like a Super M?Will go back with your list in hand.Sure hope I can meet you someday and thank you personally.Thanks,bob
Harris Guy
02-08-2005 10:07:27
 Re: Harris Guy or? in reply to msb, 02-07-2005 20:16:09
Quickest disc brake site:no external return springs(boot through the cast housing). Only on
the MH's w/ live PTO clutch. Your M &W clutch, if
a M & W, means no disc brakes. The Hyd tank cap: a 80's F6-7-8 Ford truck gas 370/429 had a PS cap
that usually was a fit, but bayonett was about
five inches short. To confirm the tranny case is a Special, I mentioned the gated shift on the 5 speed. Same gate on the Triple, but only the Triple had ten speed. Yes, there were a 'few' late production '55 Specials w/ ten, but not more
than a blend of parts(seat support different).
The rack/pinion PS pins can be made, to 'help'
wobble steering. Supply house can match old seals,
if yours are leaking. Any receipts on repairs?
You may recall a guy snoozing at an auction, while
the 'letter' color models were selling, might have been me...
