power steering
wmw
02-07-2005 12:42:39
Hello all, I had power steering oil coming out of the top of the steering column on my 255, removed the steering valve(?) and pried out the old seal after removing the column itself from the valve. The spring of the old seal was facing out(away from the valve), I have always put the spring towards whatever I an trying to keep in. Is there another seal(facing the other way) in the valve plate to keep the oil in? Thanks mw
Sam H
02-08-2005 16:17:16
 Re: power steering in reply to wmw, 02-07-2005 12:42:39
I agree that the spring ring should be on the side which has the pressure. Some seals actually have a small raised lip to protect from dust on the opposite side of the same seal. I have and old 202 and it relies on that seal to keep the oil in the steering valve on the upper side. Be sure the steering shaft is not worn where the seal rides.
