MH 44 3-point hitch
MHfox
02-04-2005 13:36:16
I have heard that MH 44 came with a 3-point lift that is only intended for light duty. It was used to lift cultivators and other light impliments. Did they also come with a heavy duty 3-point that would be suitable for larger equipment? How do you tell the two hitches apart?
Harris Guy
02-04-2005 16:45:58
 Re: MH 44 3-point hitch in reply to MHfox, 02-04-2005 13:36:16
Hitch-All was the cat.II lift shaft, which made it's debut in 1954, on the 44 RC Special, as this
legendary tractor had a unique hydraulic manifold on the top of the transmision case. Same vintage 33's lacked the braun of the Special. All
previous 3 point attempts, were as correctly
stated in these Archives, modified cultivator lifts, suited for a 30. You can identify Hitch-All
by the heavy forged lift shaft, located ABOVE the
PTO housing. Lower anchor studs, for the lift arms
have clevis strap bracing, all built to work.
goodoldboy
02-11-2005 14:07:43
 Re: MH 44 3-point hitch in reply to Harris Guy, 02-04-2005 16:45:58
i would like to know what kinda 3 point i have aon my 44 lp rc 1954 , ( iguess i aint that smart ) ( im a blonde )
