Auxiliary Hydraulic Valve Leak MF-690
TomTX
02-04-2005 02:57:26
My 1983 MF-690 recently started leaking hyd fluid from the 2-spool auxiliary hyd valve, used to power twin remotes. Tractor is cab model and it took some doing with a mirror to find the exact site of the 2 leaks. With tractor running it leaks at a fast drip from each of 2 poppets on the underside of the two-spool valve assembly. Anyone run into this problem. What is causing the leaks from these "poppet" things? Thanks in advance for your help. Tom
Toolbox
02-04-2005 11:42:31
 Re: Auxiliary Hydraulic Valve Leak MF-690 in reply to TomTX, 02-04-2005 02:57:26
I take it the poppet things you mean are in the middle of each valve slice, these have o rings on them which you will have to replace, you will have to remove the lower stud that holds the valves together and then you can pull them out, as the stud keeps them in. Another commonplace to check for leaks is on the supply and return pipes that are held in with horseshoe type clips these also have o-rings on them
TomTX
02-04-2005 21:08:15
 Re: Auxiliary Hydraulic Valve Leak MF-690 in reply to Toolbox, 02-04-2005 11:42:31
Hey Toolbox, you were right on with your analysis. After your post above, I studied the MF Parts Manual, and the MF Repair Manaul, and I can see exactly what you are talking about with the removal of the lower stud, which is threaded on each end with nut and lock washer. I dropped in to local MF dealer and bought the 2 o-rings for the poppets and they were 29 cents each, so my total may be only 58 cents for these leaks. The head mechanic there also confirmed that these poppet o-rings do sometimes leak like this. I looked in detail with a mirror and light with the tractor running and the leaks were steady drips from each poppet. The horseshoe clips on the larger return lines leak a little bit, but just enough to stay oily. I will let them go for now. Thanks so much for your help. Tom
