hydraulic fulid leak T.O. 20
David Dear
02-03-2005 10:39:02
I have developed a hydraulic leak on my TO 20 at the flange where the engine bolts to the transfer case. Can someone give me some idea on what part has failed, and how tough it will be to repair before I open it up?
Jerry/MT
02-03-2005 20:06:06
 Re: hydraulic fulid leak T.O. 20 in reply to David Dear, 02-03-2005 10:39:02
Are you sure that it is transmission/hydraulic oil and not oil from the engine rear main seal? Is it dripping out of the little hole with the cotter pin in it? Assuming it is tran/hyd oil, the is a seal on the bearing retainer to the transmission input shaft that could be the culprit. You'll have to split the tractor to get at it but that is no big deal. If you don't have a factory shop manual, get one and it'll tell you, step by step, how to do that.
With regard to the transmission input shaft seal, it doesn't look like a tough job but I've never had to do one so I won't conjecture about it. Maybe somone else can help you there. You might also try a search in this forum.
