What Tires?
Walt Banta
01-31-2005 19:36:51
Folks, Can you help me determine what size tires/type tires I need? I have an old 1945 Case DI. Presently the fron is fitted with 7:00X20's. The rear is fitted with "dual" wheels that are mismatched. On one side I have 9:00X24 with military nondirectional tread; on the other side there are two highway tread tires, and the only numbers I can read are 8X40, but they are mounted on 24 inch rims also. The tractor appears to set too high in the front and too low in the back, but the rear tires are either flat, low, or one side is smaller than the other, so appearances may be misleading. What types and sizes of tires would be correct for this industrial, dual wheeled unit? Walt Banta
Case
02-01-2005 05:52:01
 Re: What Tires? in reply to Walt Banta, 01-31-2005 19:36:51
Might post this on the "Case Board", Walt.
Walter Banta
02-01-2005 18:47:56
 Re: What Tires? in reply to Case, 02-01-2005 05:52:01
Case, I see the error of my ways, and I have followed your advice. Thanks! Walt Banta
