MF 230 power steering
Thomas D. Smith
01-31-2005 16:08:53
I have a question about this unit when the motor is shut off and you remove the filler cap on the resouvour fluid will run out, but won"t run out when the engine is running. The owner was told by a Dealer to just run it.
thanks
Tom N.E.Ga.
Big Dean
02-01-2005 11:09:23
 Re: MF 230 power steering in reply to Thomas D. Smith, 01-31-2005 16:08:53
The MF230 with a Perkins engine the power steering is filled with the engine running you then turn the wheels from stop to stop till all the air is gone refill it then replace the plug before you shut off the engine. The oil will run out the plug hole when the engine is not running
