Tractor weight
Massey Mark
01-31-2005 07:39:42
Does anyone know the approximate weight of a 220 Masey with gannon, loader and wheel weights. I need to move the tractor and am concerned about useing a standard car hauler trailer with 8,000# GVW. The 220 was built in the late 60"s and early 70"s and is a small utility tractor. However, it is larger than say a Ford 8n. Thanks
Todd Klavenga
02-21-2005 19:09:32
 Re: Tractor weight CASE D530 in reply to Massey Mark, 01-31-2005 07:39:42
needing to know tractor weight for shipping purposes for a CASE D530. it has a loader but not wheel weights/fluid in tires so basically a close tractor weight is what I need. Thanx
Todd
Jason(PA)
02-01-2005 16:50:37
 Re: Tractor weight in reply to Massey Mark, 01-31-2005 07:39:42
I couldn't guess how much it would way,but the trailer doesn't sound all that safe for it. I know my 8N is 3,100 lbs with fluid in the tires and nothing else on it so Im sure your tractor is alot more. I see some of those car trailers these days and they look a little on the "cheap" side(especially the tounge area) Rule of thumb is if you don't think its safe it probably isn't. Just my 2 cents.
