How many run 2 batteries?
our Farmer
01-31-2005 06:13:40
You guys in the colder climes, how many run 2 batteries in their diesels? Between the preheater, cold oil and compression, when the temps get in the teens, I have to hook up my 200 amp starter/charger the get enough juice to get my 65 running. Battery alone drops to 8v under the load. I have a 900cca battery in it, thinking about adding another.
John Horner
03-04-2005 22:55:38
 Re: How many run 2 batteries? in reply to our Farmer, 01-31-2005 06:13:40
Another option in cold climates is to run one of the synthetic heavy duty oils in the winter for much easier cranking. Shell Rotella T Synthetic 5W-40 is one such well respected oil which is not horribly expensive ... generally around $13/gallon at WalMart.
John
Rod in Smiths Falls, ON,
02-01-2005 12:42:38
No trouble yet starting the Perkins diesel on my MF35 with one battery. I've used the block heater for a half hour when the temperature's below zero (F).
mike in ont.
01-31-2005 16:02:33
Here in Ontario where it can get down in temp. I run 1 battery, but its about 2 feet long and about 1 foot wide and 1100CCA. It whats specd. for a MF255. For the month of Jan. and Feb. I usually have it plugged in all the time so I can get it started to feed the cows.
TomTX
01-31-2005 10:10:04
Don't live in cold climate, but my MF-690 came from factory with 2 12-Volt batteries, hooked in parallel; with only 12 Volt electrical system. I run two exact model/age/brand batteries of 650 CCA each. However, I also have a block heater that I plug in for about 45 minutes when it is under freezing; starts tractor right up.
STUDEdiesel63
01-31-2005 08:25:53
do you have a block heater on it? if not,i would suggest putting one on.if plugged in for 1/2hour,45min.it will start like it`s 60degrees out.much less wear on starter&battery,probably buy a good one for 30.00 or less.
steveormary
01-31-2005 20:44:25
 Re: How many run 2 batteries? in reply to STUDEdiesel63, 01-31-2005 08:25:53
My 706 ger.diesel was set up with 2 6 volt batteries in series to give 12 volts. Always workede good. Plugged tractor in when I had to use it.
steveormary
