mf35 diesel generator showing discharge
ric
01-27-2005 17:00:26
i bought my 35 and noticed it didnt charge i took the generator off had it rebuilt /after putting it back on it shows discharge /the more i rev it up the farther the discharge any suggestions
acmfmh
01-28-2005 12:41:18
 Re: mf35 diesel generator showing discharge in reply to ric, 01-27-2005 17:00:26
Use an electrical meter (DC Voltage) and check the reading at the battery while it is running. IF it is charging it should show over 13 volts. If the system is a negative ground someone probably did not reverse the wires on the ammeter.
You could also check the reading at the started to see if it is charging back through the system like it should.
While you are checking turn on the lights and see how the readings change. Should stay over 13 volts if properly charging.
ric
01-28-2005 15:20:09
 Re: mf35 diesel generator showing discharge in reply to acmfmh, 01-28-2005 12:41:18
i checked with my volt meter across the battery at different rpm and it is definetly charging i reversed the wires on the amp gauge and now it shows charge thanks for your help guys
Rod in Smiths Falls, ON,
01-28-2005 16:21:01
 Re: mf35 diesel generator showing discharge in reply to ric, 01-28-2005 15:20:09
I'll change mine tomorrow.
01-28-2005 04:49:00
 Who cares, if it works? in reply to ric, 01-27-2005 17:00:26
Mine shows discharge as well, but the battery stays charged and on cold mornings after starting it shows a lot of discharge. Hence, I may safely conclude that the gauge is reversed. I may not be an engineer, but I can multiply by -1.
C. T. in Oklahoma
01-27-2005 17:29:36
Just a thought, (I am not a mechanic), my 35 is a positive ground. If yours is also, would the gauge run backwards if you wired it as a negative ground? C. T.
ric
01-27-2005 17:35:37
 Re: mf35 diesel generator showing discharge in reply to C. T. in Oklahoma, 01-27-2005 17:29:36
i thought about that but i wasnt going to change it untill i got some input right now mine is hooked up negative ground
Toolbox
01-29-2005 01:26:35
 Re: mf35 diesel generator showing discharge in reply to ric, 01-27-2005 17:35:37
If you have an amp meter and it is showing discharge when the engine is running and the battery is still being charged, I would say the wires on the rear are on the wrong way around as the amp meter is wired in series and the current passes through it.
If it is an amp meter do not connect it to ground.
C. T. in Oklahoma
01-27-2005 17:55:50
Ric, You might look at your serial number plate, if it says "Manufactured in Covington, England" or something like that, it is positive ground. C. T.
ric
01-27-2005 18:49:26
 Re: mf35 diesel generator showing discharge in reply to C. T. in Oklahoma, 01-27-2005 17:55:50
MY SER# IS SNM210996 I BELIEVE IT IS A ENGLISH MF-35
