Fireing order MF85
jsskydiver
01-26-2005 18:13:16
I have a 1959 mf 85 with a continental 223 engine. I'm getting gas in my oil and some out the exhust. The firing orderin the book of 1342 it will not start and back fires, but the firing order of 1234 it will start and run at very low rpms. and only running on one or two cylinders.
Len
01-28-2005 20:46:18
 Re: Fireing order MF85 in reply to jsskydiver, 01-26-2005 18:13:16
Sounds like you"re off 180 degrees. Move the the wire for 1 straight accross the cap and do 1342 starting there.
jsskydiver
01-27-2005 16:00:22
I check for TDC and number one on the disributor cap. goning counter clockwise and my firing order is 1234 it starts, only will run at idle with full throttel. Will not start if I put the firing order of 1342 just back fires.
STUDEdiesel63
01-28-2005 21:46:51
 Re: Fireing order MF85 in reply to jsskydiver, 01-27-2005 16:00:22
how long has it been since the tractor ran right? has distributor ever been fooled with? maybe loosen distributor and move it one way or the other as you crank it over,see if you can get it to fire on 1342.
STUDEdiesel63
01-26-2005 21:12:23
it`s late,typed numbers wrong,1342 will(should)run.are you going the right way around the distributor cap?
STUDEdiesel63
01-26-2005 20:50:54
1432-it will run
