air in fuel system
russell muelle
01-23-2005 17:27:35
Ihave a 1988 231 massey with the 3 cyl. perkins engine.I keep getting air in the fuel system.To get it running again all i have to do is take the return line off the filter and spin it over.I have looked at what i can.But cannot find a Anyone else had this problem and can help.Please let me know.
davids
01-23-2005 21:18:24
 Re: air in fuel system in reply to russell mueller, 01-23-2005 17:27:35
russell, have you checked the return line at the rear of the fuel tank? If the return line is pinched somewhere or blocked at the fitting,the air bubbles that are in all systems cant escape and build up in the pump until the engine dies. By opening up the system at the filter head, you give the air a place to escape and it will run till bubbles build up again. Good luck, Davids
mike martin
02-09-2005 22:48:33
 Re: air in fuel system in reply to davids, 01-23-2005 21:18:24
some times the little brass washers in your fuel line nuts get worn or fall out. of you see fuel spittind or bubbles anywhere on your fuel system fron the fuel lift fump to the injectors stop it.
